B&O add aftermarket sub
You put a 2 ohm speaker wired in parallel to an amp that cannot handle a 1 ohm load. Dual 2 ohm voice coils wired in parallel = 1 ohm final impedance. Of course it won’t sound right and of course you are clipping at half volume. The resistance is too low for the stock amp to handle.
And even when you do get the impedance correct, once again, the volume of the b&o enclosure is still unknown so for you to just stick a 8” sub in there and expect a quality sound is literally like shooting in the dark. The odds are stacked against you.
This is FRF, not a sound lab.
I believe the ’17 Sony was a single voice coil and wouldn’t be surprised if the ‘18+ b&o is as well. That said, I believe the F150 community; it’s in my ‘added a sub’ thread did the swap using both the kicker and pioneer without the clipping reported on the 18. I think the signal was previously identified as the issue with adding a sub to the ’18.
dhmcfadin
Both the Sony and b&o are dual voice coil. I’ve had both systems.
If you wire in series, you will be fine or if you pick a sub with a higher impedance, that can work too. But dual 2 in parallel is too low.
BIGW0RM
Highest Access Member
Pirate
Thanks for all the help DH and Smurf. I returned everything and went back to stock. This is just too much of a PITA. God I hate this truck.
Everything about this dam truck is a PITA.
Anyways, you two are both WAY cool and I sincerely thank you both and the community.
But Ford and this stereo and eat a big fat _ _ _ K.
Damn. I hate to hear of someone having to tough out living with a vehicle they don’t like...
I’ll give you $500 cash for it. I’ll even come pick it up.
My bid is $1000 hard cold cash! I will come pick it up tonight before Smurf and DH even know what happened...
pfft. Already on my way. The only question is, which one of you losers is going to arrive 2nd. :p
Quaesta
The other option is to find a reputable shop and have them do the work. You can sit back and enjoy your tunes without the headache.
BIGW0RM
Pirate
Oh man. I’d totally do that! But I already started my buy back.
