- Joined
- Dec 16, 2016
- Posts
- 17,554
- Reaction score
- 27,029
You put a 2 ohm speaker wired in parallel to an amp that cannot handle a 1 ohm load. Dual 2 ohm voice coils wired in parallel = 1 ohm final impedance. Of course it won’t sound right and of course you are clipping at half volume. The resistance is too low for the stock amp to handle.
And even when you do get the impedance correct, once again, the volume of the b&o enclosure is still unknown so for you to just stick a 8” sub in there and expect a quality sound is literally like shooting in the dark. The odds are stacked against you.
This is FRF, not a sound lab.
I believe the ’17 Sony was a single voice coil and wouldn’t be surprised if the ‘18+ b&o is as well. That said, I believe the F150 community; it’s in my ‘added a sub’ thread did the swap using both the kicker and pioneer without the clipping reported on the 18. I think the signal was previously identified as the issue with adding a sub to the ’18.
