B&O add aftermarket sub
Wayne Twombly
United states
So if my head unit feeds the tweets. That means they are not connected to the b&o amp. Doesnt that mean once that amp is gone , the tweeters will still work ?
dhmcfadin
No because communication to the b&o amp is can-bus/ a2b. It’s a digital signal vs analog. Like I said above, once you remove the amp, the ipc thinks there is nothing connected so it mutes all sounds and reverts them to the dash speaker. I assure you, there isn’t a way around this. Plain and simple.
dhmcfadin
I do have to ask; why? I hope you aren’t trying to avoid running new wires to the tweeters. That’s not the right way to do this.
Wayne Twombly
United states
I'm trying to avoid adding another piece of equipment. I've ran them From my front door speakers . Works fine. I dont know why people on forums try to push all the expensive stuff.
I actually turned off the fake engine noise and I'm using 3 lc2i links. After the b&o amp. Works ok to me.
Wayne Twombly
United states
I must say you are the only guy on this page that has any idea. That must mean this is t that popular ? Or not many people have the balls to RIP into a 70k truck. ? Either way , have a great holiday and I'm gonna delete my profile .
dhmcfadin
Ok, well use an lc2i on the sub harness and be done with it. If you are happy, that’s all that matters.
Wayne Twombly
United states
I used lc2i on all channels. Total of 3 After factory amp. Turned off fake engine noise. And ran tweets from front doors. Why do people make it seem so complicated ? The lc2 will handle about 400w per channel coming in. Then split off to the amps. Dial in desired sound. And done. No need for an 850$ product. Maybe when that type of product has more than one option I'll change stuff up again.
Ocotillo Boy
Removed the B&O amp and replaced the entire system with the following:
NavTV Zen a2b replacement interface
Helix dsp pro mk2
AudioControl 6.1200
AudioControl 4.800
AudioControl 1.1500
Front tweeters- Morel mt120’s
Front mids- Morel cdm600’s
Front woofers- Morel TIW 634 ft titanium’s
Rear doors- Morel Tempo Ultra Integra 602’s
Subs- 3 12” Stereo Integrity MK V’s
Full floor, ceiling, rear cab and door sound treatment- second skin vibration dampening and closed cell foam
Custom vapor barriers
The list goes on and on
Do you have pics of this install? Didn't even know audio control was making amps now! How do they sound??
