Az Newbie
dsmless
tucson AZ
Well I messed it up- I have the Screw you see pictured. So much for making a good first impression. The other vehicle there is a expedition I use for hunting/camping.
dsmless
tucson AZ
Nice truck, are the boarder patrol raptors priced really well? Regardless, nice to have a government maintained vehicle!
It was $18k when I got it in april 2021. For this price I knew it was gonna be far from perfect. It was only factory required servicing at the factory intervals. The first year I had it I replaced the shocks and all the fluids.
Then I replaced the following items just to hold up to the desert here.
- OEM radiator for an aluminum 3 core radiator
- all front suspension bushings and tie rods along and stop cam kit
-methods 17” rims an cooper 35” tires
-painted the front/rear bumper and trim with black bed coating paint, really like the way it came out.
- replaced the factory basic radio with a 9” touchscreen amazon special (been going good for 2 years)
-added a back up camera
The interior is cloth and it does not come with a sync or trailer break nor the aux outfitter swicth bank. And also no sunroof. Given that this truck lived alot in the desert, there was dust everywhere I had to vacuum out.
The biggest issue I had when I go it was that the evap core was clogged to the point that I had very little airflow out the vents. So instead of dropping the dash I just cut a piece out of the HVAC plenum behind the glove box and scrapped a thick layer of soot from the evap core and clean it so I could get airflow back in the cabin, plastic welded the section back on and airflow is good.
dsmless
tucson AZ
Welcome to the forum, can't wait to see pictures of you scab, who's screw is that?
No scab here, I messed up on the pitch. Heres more pics of my screw, all the work done is in my garage shop. I do aluminum welding so I always wanted to make a kinda baja chase vehicle.
Made aluminum bed cap toppers with a grab handle and a headache rack that the roof rack attaches too. Installed a front and rear winches (have used the rear one often to get out atvs) and alot of other stuff. Being that its not pretty and shiny anymore I can add stiff to it as I need them. I just made/added front fog lights this week. Im gonna coat /paint it with white bedliner once all done. I have done the tailgate and like the results.
