Anybody installed the Whipple tune yet??
JeremyFXDWG
I finished the install as well, it went smooth and the truck runs amazing. I am not all that impressed by the CAI. It’s not bad but I don’t know why they didn’t just make a top for it? I might swap it out for the injen I have on the bench.
JeremyFXDWG
i been running toyo rt 35s. so per the instructions was just changing to 2777mm
I snapped a pic before I tuned the truck in anticipation of having to renter the info for tire size. This sis what it said before flashing. I did not have to renter it so can’t comment in the process.
OPT PRIME
I wasn't a fan of how the air temp sensor is just shoved into a grommet. Here is the Ford Part # for the OEM connection. I may use some Devcon plastic steel with some black dye to glue the OEM connection into the new pipe. edd945dc05cbd7fcfea18ea31654461e.jpg
---------- Post added at 02:23 AM ---------- Previous post was at 02:20 AM ----------
Here are a few pictures.
spark plugs with 9k miles. dirty as hell.
You have something else going on there. My plugs have 7,000 miles and are light coffee brown. I always run 93 from a name brand vendor. No fuel additives to date.
10SpdsOfFury
Jacksonville FL
Here is the dirtiest of my Plugs at 7000 miles
solarwinds
DFW
I run it hard. Only 93 all the time and 91/92 when out west. Manual says change every 12k when under heavy use which is why i changed and pointed it out.
jikjak
Canada
So is it better to stick the SP550 spark plugs or go with the NGK LTR6IX-11 6509 spark plugs?
Also, @solarwinds , you mentioned buying your plugs at Ford Depot, you have a link to that shop? (cant seem to find it online)
thx!
OPT PRIME
That is really odd. In my track cars that I run hard the plugs are usually closer to white than coffee, due to the extreme cylinder temps. My stock Raptor is the same way. Those plugs look really rich or a lot of oil is getting back in those cylinders.
jikjak
Canada
Another spark plug question.
Would it be a idea to use plugs that are one step colder?
would that reduce the chance of the spark plug causing preignition?
6 is stock temperature, so perhaps use 7?
kpg81
SoCal
That's because you run them hard, and you are running a little lean.. which is why you see a lot of white. I'm surprised the Raptor would have white on the plugs, unless you are WOT all the time and maybe a higher elevation.
---------- Post added at 09:15 PM ---------- Previous post was at 09:14 PM ----------
Yes.
Use the Motorcraft SP542's and gap to .025"
That's what I'm doing and if you Google it, many other Ecoboost 3.5 owners do the same for many reasons.
