Anybody installed the Whipple tune yet??
jikjak
Canada
Awesome, good to hear another positive review on the whipple kit! I cant wait to install mine but it will have to be a while as Im waiting for a full race intercooler to arrive (installing a winch).
is it a requirement for this kit to get new sparkplugs and have then gapped to 0.025"?
Which plugs did you go with? If needed, id like to order some and have them ready.
10SpdsOfFury
Jacksonville FL
You don’t have to buy new plugs you can just gap the stock plugs. I went ahead and got new plugs just to have them ready like you said, stock plugs are SP534’s and aftermarket you can use NGK LTR6IX-11 6509’s.
I also bought a really nice spark plug gap tool off amazon. Works awesome
Torque Solution Precision Spark Plug Gap Tool for 14mm Threaded Spark Plugs https://www.amazon.com/dp/B073G7LCSL/ref=cm_sw_r_cp_api_hEtqAbXVRGEGP
solarwinds
DFW
little more info on my experiance installing. besides the step #20 in my previous post on this thread about the out hose and remove plastic shield. here are a few pictures.
spark plugs with 9k miles. dirty as hell. replaced with sp550s from ford depot only place i found them gapped perfect to .025 out of box. every place online doesnt have. i ordered from a few places online saying they have but they really dont.
the fan unit was sucking in the wiring harness and cut thru the plastic cover and into the wiring. had to repair this. added some tie wraps to make sure this doesnt happen again. factory clearly didnt have enough harness wire management to keep it from being sucked up and cut.
when taking off oem cac about 2-3 ounces of gunk liquid came out all 3 locations. both right/left in hoses, and out hose. (can you say weephole, for you Sasquatch)
whipple cac is a beast of a cooler. thing is solid and heavy
whipple cai is also a beast and solid built. (i had the roush before). whipple’s is much better built imo
tune and tomahawk also easy to use and no issues so far
will update on performance shortly
ray101381
Alexandria, VA.
Stock plugs are not sp534’s! They are sp550’s CYFS12YPCT. I pulled the stock plugs and bought brand new replacements and they are indeed sp550’s. Sp534’s are CYFS12YT3. I mistakenly bought the 534’s so if anyone wants a brand new set pm me
solarwinds
DFW
i did the tire size change step and now its throwing me the dreaded orange wrench. see service manual.
Spartan1
Mars
That is interesting about the "gunk liquid". I was reading this page and watched the video link of the install. I'm not sure if it is worth the $400 or not but it sounds good.
2017-2018 F150 & Raptor 3.5L EcoBoost UPR Dual-Valve Oil Catch Can 5030-221
solarwinds
DFW
^ ya i read alot about catch cans. just not sure i want to install one. after seeing this liquid not sure if its because the oem cac is just cheap junk or a catch can is really required.
kpg81
SoCal
What size did you change it to ?? Not good because I need to change it for 37s
---------- Post added at 05:32 PM ---------- Previous post was at 05:31 PM ----------
Why not use the SP542s....
