AFE Diff cover install question
zemuron99
Seattle
OK, so received my AFE finned diff cover kit today. Test-fitting everything together, and it seems the included o-ring is larger than it needs to be (see upper left in the IMG_2229.JPG pic). Is this common, they just use one size for everyone and you trim-to-fit? I'm not sure I want even a minimal gap, seems it should be a solid unit. Did they send the wrong one and I can contact them for the right one? It's fully inserted in the channel and around the bolt holes except at the corner.
MTF
Celebration, Florida
I would redo the seating again, seams like you started it in one spot and worked your way around. I believe you stretched it.
Lay it on top and carefully press it into the straight parts first making sure you have equal lengths on the corners.
Then work the oring around the bolt holes.
zemuron99
zemuron99
Seattle
Will do, MTF. You're right, that's how I did it. Will give it another try in the AM. Thx, Thomas.
MTF
View all the Gale Banks diff cover tests on YouTube before installing that.[/MEDIA]
Well, he's definitely on to something that's for sure.
BUT, since I fried every bearing in the rear 5 years ago,
I installed the AFE cover and switched to Mobil 1 gear oil, I've been trouble free.
So it's better than the stock cover for now.
Dane
Littleton, CO
I have that cover and I second MTF's advice. It'll fit, you just have to get it to balance out a bit. It just takes a bit of fussing with it. Basically distribute that "slack" around the ring. You have it stretched a bit even though it doesn't seem like it. Lay it in loosely. AFE makes good stuff.
Kirby Lastinger
Lakeland, FL
The AFE was my first choice, but I went with the Ford Performance diff cover after watching the banks videos. Made good sense to me
zemuron99
zemuron99
Seattle
Well, Gale's credentials are unimpeachable for sure. Interesting series, I especially liked the parts with the clear covers. I'd often wondered just what goes on in there. The flat-back cover demo was eye-opening for sure. I do wonder though, w/out eyeballing it for ourselves (or for himself) if the contention about starving the ring-pinion interface and/or pinion bearings really holds true. The lube aeration is pretty evident though, and is going to degrade lube performance. So...I've ordered the Ford performance cover, and when it arrives I'll compare them side-by-side to see which I prefer. I do like the looks of the Ford cover for sure. Couple of other comments I've read critiquing the Banks videos mention 'thousands' of hot-shot truckers using stock covers who don't burn out rears, but there sure are some who have, as well as some heavy RV'ers. There's also a smaller number using aftermarket covers who haven't had any issues either (which I why I question the 'starvation' hypothesis). Anyway...the AFE unit is still sitting in the garage, just waiting for the Ford unit to arrive (ordered Sat 6/22) later this week.
Just outta curiosity, has anyone installed an AFE (or similar) cover AND the Hellwig anti-sway bar? Will they both fit? That may be another issue that pushes me towards the Ford Performance cover...
