- Joined
- May 17, 2021
- Posts
- 483
- Reaction score
- 743
Nice... jealous! Keeping thinking about doing something similar, but lazy and just strap in my 10lb tank
It's DC 12V and draws 50A through two wires. You should connect it to the battery directly.I have a 2023 Ford Raptor, 37 package with pro power on-board.
Question: Was thinking about getting:
a) BuiltRight Industries BEDSIDE RACK SYSTEM - DRIVER REAR PANEL (Part #102003)
b) ARB TWIN MOTOR ONBOARD 12V AIR COMPRESSOR (Part #CKMTA12).
To power the compressor, can I just plug it into the pro power outlet? I haven't seen outlet connection kit/option. Is it not possible? Amp limitation?
From my understanding, the problem is the amp draw on the compressor. You arent gonna get 50A out of pro power or a 120V plugcan this not hook up to pro power onboard?
damn! the one thing it could have been useful for! lolFrom my understanding, the problem is the amp draw on the compressor. You arent gonna get 50A out of pro power or a 120V plug
looks great! what bedrug is that?Mounted the ARB twin compressor to the builtright molle panel just like OP. I used OP instructions but did mine in slightly different order so I didn't have to remove the molle panel to install the bracket. Also, didn't have to remove the front cover of the ARB.
