ARB Twin Air Compressor Install
JayRods
Manteca Ca
Just finished my ARB twin Compressor Install. I won't go into to much detail the pictures will tell most of it. Had to tweek it here and there to get the seat to fold up like its supposed to. I ran a 4guage power wire from the main battery back to the twin 40amp fuse block. This will run the 2-way Radio and the Compressor with no power loss issues. I mounted the 2-way Icon Radio unit there and made a small bracket to mount the head unit down at the bottom of the dash.
JayRods
Manteca Ca
Few more. Baja Raptor Run here I come :)
JayRods
Manteca Ca
I really love this. Any chance I could pay you to fab one up? I do not need the fb radio pard just the dual air compressor mount.
Thanks this is working really well for me.
At this time I really don't have time to make another one. The Welding shop that cut out the steel plates for me, I'd would think he still has everything in his computer he can re cut it all again. He might be able to cut and ship. I could help you set it up for Welding.
I would cut the ovel holes in the lower mounting plate longer. Need to push it back as far as possible to still be able to fold the seat all the way up.
I completely understand as I barely have time to do the stuff I need. Ya if you could see if he has the files or give me the info I could reach out to him. I can find someone locally to weld it. Thank you for the info and reply
JayRods
Manteca Ca
I will text him today and let you know.
Next onto the power supply. There are 2 small 12v invertor batteries right there under that seat but they are wired to 24V. I could have gotten the 24v ARB Compressor, but decided not to mess with that factory invertor system. So I ran a dedicated 4 gauge wire from the battery. There was already a wide open 1/2" hole in the fire. Not sure why. I made the hole bigger with a step drill and I use glad hand seals from semi trailers to as a grommet.
I also use this fuse block at the batter to tie in all of my goodies.
Ok thank you please let me know what he says
JayRods
Manteca Ca
Yes he said he would cut it, weld it, and ship it. He is leaving town on the 21st for a while so call him soon.
I will PM you his number. I need to tweak a few things on it to make the next one better.
I will call him this morning.
