BLACK_RAPTOR
- Joined
- Feb 20, 2015
- Posts
- 12
- Reaction score
- 1
Thanks. I might have to try that. It feels dangerous going over bumps. Did you get the ramp option? I have it on my 18 and was wondering if I can remove them and put in my 19.
I haven't gotten on it that hard yet, but I did lower the tire pressure to 35 in front and 34 in back. When I drove it home from the dealer they were 46 all around and when I got home the outside 1-1/2" on each tire was clean, it had not touched the ground. That leaves a lot of rubber not working to keep everything in control. After I get used to it, I plan on going to 33 and 32 to see how that does. I now have about 300 miles on it and by this weekend I will have over 500 so time to "test" it out. I have found out that manufacturers put high pressures to help fuel mileage, although radial tires are not that effected (mileage wise) by pressure. However if only part of the tires touches the ground, it will help rolling resistance, and help mileage.
Also a couple of times I did need to put on the brakes harder than I like during the brake in period, and did not experience much front end dive at all.
