2018 New motor recommendations
FordTechOne
Detroit
I’m not sure if the commentary is because you think I’m being argumentative - that is not my intention. my point is responding to the statement a non HO gen 2 will not work in an HO application. without any technical reasoning, I don’t see why this would be the case.
Nope, no issue. Just clarifying that a 2017-2020 Gen 2 3.5 non-HO cannot be used in place of a 3.5 HO due to the internal differences. A 2021 3.5 it not backward compatible per Ford, but the aftermarket may have already solved for that.
Again no intention to discredit you. Gen2 raptors are having crankshaft failures, it’s something I’ve seen on this forum a number of times and @GooseTuned has seen on some of his customer’s gen 2
Never seen a single stock one fail in my experience. On the modified trucks, has analysis been done to determine root cause? Forged cranks do not just break for no reason.
full-race geoff
AZ / NJ
As you might imagine, the crankshaft failures are catastrophic and it’s difficult to take anything conclusive away.
My speculation is I belive the harmonic balancers are failing and causing stress riser fractures to grow along the counterweights. In almost every high mileage raptor I’ve seen the crank pulley is shot
As best as I can tell, when a gen 3 crank is installed in the Gen 2 block there have been zero crankshaft failures. Of course none are being run with wonky harmonic balancers
dillard09
College Station, TX and Socal
He is what was left of mine in the oil pan. Just had an intake and a tune at the time. Let go at just over 100k. It is a 2017
dillard09
@full-race geoff I think you could be right. Here is a short video of what mine did. Drove it 1 mile after that and the crankshaft came apart and went through the oil pan. You can see the parts of it in my other post
  • 20200618_173548.mp4
    1,015.4 KB
Old-Raptor-guy
USA
I don't think you are being argumentative. An non-HO will bolt up to the truck and run, there is no doubt about that. I am just not sure why you would want to.
But alas the crankshaft issue.
I could be wrong, but having held a non-HO piston in my hand it appeared to be cast not forged where I believe besides the lower CR the HO piston is forged (could be wrong on that for sure). Have seen 7 or 8 non HOs with broken piston skirts in the last 2 years.
full-race geoff
AZ / NJ
HO pistons are cast, hyper-eutectic aluminum with a steel ring carrier. This is similar material and construction to non HO pistons. The difference is compression ratio and oiling ports
Coop65
Mississippi
You likely toasted a bearing or three. What is known for SURE is that poking it with low oil WILL cause the oil pickup to uncover and suck air. Adam @ZFG Racing discovered and posted about it a while back. It will suck air and drop oil pressure with full oil if you’re tuned running more power.
So I have to ask a question allbeit maybe a stupid one but knowing the possibility of this sump sucking the air because of the situation of "punching it" from a launch or low speed wide open punch---- are there any for sure DO's / DON'TS to hopefully avoid having this sump suck air ??? I just got my new engine in and have just done the 3rd oil change at my 5 K mark.... I just don't want to be ******** up a new engine by playing around.... but of course you want to enjoy the power of the engine that is GOOSETUNED !!! Seriously I want to avoid the risk of that happening if I can so anyone that has got this figured out could you give me your guidance ?? Thanks in advance--- being down for 3 months without my truck was crap and I was blessed by GOD to get my engine replaced so any good guidance would be much appreciated !!
I'm fairly new here and had never posted a pic of my truck so I thought I'd better or it never happened !!! LOL
