17 to 21 - Initial impressions
NJ2020
Twin Cities
Front and rear suspension are much closer in terms of how they handle bumps, particularly noticeable with mid-corner bumps. My 17 front suspension would soak it up and then it would hit the rear and break traction. The 21 rear is much more settled, probably as much as we can get without independent rear.
I'm looking forward to some more seat time when I can test the sport and off-road suspension settings on the same stretch of road. Sport does reduce body roll, but haven't been able to see how it reacts to bumps (mid-corner or otherwise).
I’m running 38 psi which is probably on the high end of FPs recommendation, but it feels a lot softer than my 2020. Not sure if you agree between the 17.
BoostCreep
SoCal
Have you ridden in or driven a Gen2 with deavers, if so how does it compare?
R
Raptorlaw
I'm 38 front/36 rear, which is what I ran on my 17, but feel like the 37s should be even lower. Will try that this weekend.
As for the comparison to the 17, the 17 was softer overall, but also much less controlled. I had the shocks rebuilt at 40k and would still feel continued moment well after hitting any big bump. The 21 soaks up the same bumps with no continued movement. The 19/20s were probably better controlled with the live valves than the 17/18s, so that comparison would be helpful.
MSP
Do you feel like the 37s reduced power? Any 0-60 times? Curious how well Ford did on adding the 37’s. Hopefully loosing a little bit of mpg and wheel travel are the only trade offs.
FORDONLY
Hopefully the 37 is not much different than the 35 speed and feel wise
