1100 Miles 36 hours BAJA
Deleted member 12951
Guest
Loose vacuum, IWE engages. Have vacuum, IWE’s are sucked away from the engagement of the hub
bp299
Very cool. Going to be headed down there in March. What tire pressure are you running? Do you pack a compressor?
r3run33
great vid how is the water temp? did you need a wet suit? also as for the Vac lines. is there a trail fix? what did you do while on the trip. Great info for us to carry these parts for repair etc. the IWF have been a problem or weak link for ford for very long time. hey what about maps? did you get this route form someone? loll maybe from Mr Steele. I think he has the bay on his one of the 50 Best of Baja
KentSD
KentSD
www.BookBaja.com Baja yacht Support
San Diego
Nice trips, I'm still uneasy about driving alone in Mexico.
This fall I am headed back to Utah......
Can you please explain more about the vacuum line? exactly which one and maybe even the part number. Sorry, I know I am asking a lot but I would like to prepare. I also do my runs alone (wife & I), I would like to add this part to my packing list, if it's possible to change in the field.
Is the truck drivable when it breaks?
Its a check valve its about a $2 part but they will charge you $277 to replace it. I also showed the dealer when i dropped it off and they laughed... was in the shop 2 weeks... they thought it was the tranny then the hub etc... And it ended up been the check valve i told them to change. Sometimes i really wonder Ford.
---------- Post added at 08:37 AM ---------- Previous post was at 08:32 AM ----------
Every time I read one of Kent's posts I wonder if I'll ever make enough money to not give a **** and disappear for a week at a time and beat up my 70k truck + 10k in mods.
Living the life! I find these motivational, keep 'em coming!
HAHA!!!! That was very funny amigo! I wish i was only 70 + 10
I see the 619 in your name fellow San Diego man
---------- Post added at 08:46 AM ---------- Previous post was at 08:37 AM ----------
I bring two full size spares and tire patch kit. Good idea to have a Compressor.
On the 37s i drop down to 30 PSI sometimes even keep it around 27
---------- Post added at 08:49 AM ---------- Previous post was at 08:46 AM ----------
No i don't ask for anything from Cameron. These are all routes i have tried over 10 years of trips. I have a lowrance HDS 7 that i use to map everything. I have also used leadnav to help find my way a few times. I also Look at old race maps and see if there are some cool routes.
I have found some bitchen routes and lost some cool ones due to hurricanes.
-I really want this other route reopened after this last hurricane down towards Agua Verde and i have already talked to the local ranchers to clear it out if i wanna pay for the fuel. So im thinking about it.
