- Joined
- Dec 16, 2016
- Posts
- 18,219
- Reaction score
- 28,652
There is still a Raptor supplement manual ... right ?Ok I found Fuse #62 10amp blown.
Is a single set of Squadron Racers too much for this 10amp circuit?
Why is Aux1 10amp and the other appear to be 15?
@Baja Designs
I have a 2022 37" with the factory fogs changed out to Baja Designs S1 and Squadron Pros jumperrd together on the factory headlight fog switch wiring, and a set of Squadron Racers on the factory Aux 1.
Squadron Racer Edition LED Auxiliary Light Pod - Universal - Baja Designs - Off-Road LED & Laser Lights | Automotive, Jeep, Truck, UTV, ADV, Dirtbike
Baja Designs is proud to introduce the Squadron Racer Edition, with 4,300 lumens. The Squadron Racer Edition throws light an average of 40% further than the Squadron Pro with High-intensity LED, housed in hard anodized and powder coat cast aluminum. Enjoy nearly 50,000 hours of bright, efficient...
S1 Black LED Auxiliary Light Pod Pair - Universal - Baja Designs - Off-Road LED & Laser Lights | Automotive, Jeep, Truck, UTV, ADV, Dirtbike
Baja Designs offers high performance LED lights and light bars for off road trucks, UTVs, and ATVs. Baja Designs is The Scientists of Lighting, contact us today for more info!
so, 6.6 + 2.840 = 9.440 @ 13.8v calculated via detailed specs given by B/D. so if voltage is lower, you will need...
Wait for it...
MORE amps
From above, a drop to 13.0 amps is enough to hit the magic 10.0 or close enough to it.
When you get fancy new off road lights, if you don’t know exactly what you’re doing, it’s best to ask FIRST, before the blown fuses. Why?
Because it doesn’t always take a shift in the variables of Ohm’s law to create a blown fuse, it could also be caused by poor electrical connections, severely bent wires, broken multi-strand conduit, a shorted circuit, even a once overloaded circuit could be damaged enough to create an overload scenario, drawing more current than the fuse will allow.
Remember:
Only YOU can prevent Raptor fires.
Violating Newton’s laws carries a mandatory minimum sentence.
Violating Ohm’s law also carries a mandatory minimum sentence.
ETA: Hire someone to rewire the circuit correctly.
