Aux 1 not functioning any longer
Yeah, fuses don’t blow for no reason.
If I read correctly, you had 2x sets of lights on up fitter 1? that’s 4 lamps total. IIRC the b/d squadron pros ( i know, not what you have but I’m drawing a blank on “d2pod” ) are rated 3.1 or 3.3 / cube. 6.6 x2 =13.2 amps... give or take
as previously posted, Jen Tres up fitter 1 = 10a.
you either need a relay or move a set to another up fitter.
goodshot
Moon
My aux 1 on factory wiring with Squadron Racers just went out.
Is replacing fuse 62 the answer?
goodshot
Moon
no clue. with only half the information, we cant answer that.
I don't quite understand the gen 3 upfitter switches and their amperage ratings etc.
I have a 2022 37" with the factory fogs changed out to Baja Designs S1 and Squadron Pros jumperrd together on the factory headlight fog switch wiring, and a set of Squadron Racers on the factory Aux 1.
I am not familiar with where the fuses and connections are since I used all the factory connection points.
Last night my Aux 1 Squadron Racers went out.
