What is your buffer of choice?
BossRaptor
Az
So took my 19 Raptor out yesterday and got off trails that im normally on. Short story long, I scratched the **** out each side. I bought a all white non sticker Raptor because I knew this day would be coming. I need to learn how to buff this truck myself because im a firefighter with more time than money. What buffer would you all recommend that isn't big money? And has sum quality to it . What products would be best? Think most or all of the scratches will come off with a little work. Weather in Az has cooled off so im up for the challenge for sure!
1BAD454SSv2
HELL I ZONA
RUPES Bigfoot LHR15 see if can find used on on ebay or craigslist for cheap . New they are expensive . If it needs rebuild 95 dollar flat fee through RUPES repair center .
Hagasan41
Florida
I'm a Rupes fan and have more polishes and pads than I care to admit.
You've got several different choices as most manufactures each have a polishing machine offering. I'd advise yout to stick with a Dual Action polisher as it's the least likely to burn through your clear coat like a Rotary polisher. One of the easiset polishers and the one many detailers and enthusiasts go with is the old school Porter Cable 7424XP. I still have my 15 year old PC 7424 and it still works great.
For a big box store option and since price is a factor, consider the new Harbor Freight 6" DA made by Bauer. I picked one up for the daughters boyfriend (so he stops asking to use my machines) and got to play around with it. It seems like a decent machine with good value, ergonomics and power. It did exhibit a bit more vibrate than I'm used to but that's to be expected from a lower priced machine. I would probably switch to a 5" backing plate for a bit more correcting power and manuverability as persoanlly I find 6" pads to be a bit akward. Check it out...
The real magic comes with pad choice and compound. Several options including some from Adam's that won't break the bank. I think you can pick up Meguiars M101 at any of the major autoparts stores to keep it easy. Works great but can be a little dusty.
Good luck!
AFPhysO
Colorado
I use a Cyclo. Covers a lot of ground, comfortable, and easy to use. Doesn’t have the super high RPMs though. But it’s nice not really worrying about burning through a finish. Plus, you can buy bristle heads to clean carpet and upholstery.
