BlueSVT
Skype-sex????
Wiz you stood me up the other night
Sent from my thumbs using Tapatalk 2
Yes, Then the other side of the relay will energize the electric magnet in the rear end to throw the locker.. The only thing I have to look at is backfeeding the locker circuit I may need a diode..
Also the circuit needs 30 amp protection put into it...I forgot that in my equation as well..lol
Wouldn't you need two diodes? One for normal operation and one for bypass operation?
-Greg
When the switch is thrown to energize the relay the circuit (fuse) will be disconnected shutting down all ABS and TC function. At the same time on the other side of the relay it will put 12 volts down to the hot side of the locker wires. Thats where I will be back feeding into the Computer I don't think it's a problem but it will be looked at with an amp gauge.. The other wire on the locker is just a ground.... 1 diode needed (maybe) just for the hot...Ground is ground no worry's
Holy shit dude... that sucks.Well fellow snowballers, I probably won't be making it out there. I'm currently sitting in a state troopers squad car waiting for a tow truck to pick up my raptor. Went into the ditch and hit a road approach. Popped the front drivers wheel which we changed, cracked the drivers front fender, lost some of the plastic fender flare, bent something major in the suspension that renders my truck undriveable. Worst day of my life knowing I almost certainly won't be able to participate in the snoball. It is a sad sad day for me. Ill update with pics and more info when I receive info.
