Wiz's Build
Bar
SoCal
That front TT bumper is still one of my favorites and the best looking bumpers out there. Looks great. Thanks for the pics.
SVTBuckeye
Northern California
Thanks for the spring install pics Wiz. I just ordered a set of Deavers from SDHQ so I'll be installing soon.
wiz1500
wiz1500
Are you slowly moving your build thread from the z to here? Looks like old photos.
I like the winch / light / bummer set-up. What winch you running?
Yukon Joe
GREAT LAKES RAPTOR EXCURSIONS
No winch up front Joe...I use the winch plate in the bumper for my spare battery's instead..
My winch is in the back... I removed the spare hanger and wended in a plate that holds a 12000lbs Warn M class..
I then took my trick SDHQ rear T.T. bumper and started modifying it..
Licence plate light bar with a pass threw pipe so I can hide the wires..
I also installed a back up camera and moved the trailer light connection up into the plate.
Quick side note...I made the center counsel look right....This is how Ford should have done it..
Pynenut
Las Vegas, NV
Hey Wiz, any tips on removing the bed? Other than the 6 bolts and filler plig, any other obstacles to look out for.
--When in doubt, Throttle out--
Sent with my iPad
sonoma
Dispatch
FRF Lady
California
Is the only difference between Wiz's custom console and the stock 2013 console the different material used?
wiz1500
wiz1500
Sent with my iPad
You got it. 6 bed bolts and the 3 bolts in the filler neck.
Make sure you pull the clamp thats on the filler pipe down where it runs under the bed rail. It's right above the frame..
Also you just have to be careful with the rear bumper so you don't scratch your fenders...Tape the edges up really good or remove it first.
