White Smoke
dewalt
A cold engines first priority is to heat the cats. So they play with timing etc . Learn your truck
soulsea
SC/AZ
There's apparently a service bulletin on this issue that says that the issue is a faulty valve cover gasket and requires replacement (not sure if it's just the gasket or the whole valve cover).
Osteoblast
My 2018 was doing this, manager saw it when I brought it in for a defective heated seat. I referenced this site after they started the “what oil are you using” routine.....they checked the turbos and there was oil residue all around them. Getting new ones covered under warranty and hoping they are not on backorder
kid icarus
Nintendo
Are they only replacing the turbos? If so, how will that help anything since they didn't solve the issue of oil getting in them.
