GEN 2 Whipple Stage 1 Kit Feedback Thread!
Feedback on Whipple Tune
  • Total voters
    199
Sharkus29
Kickin it in Canada!
Installed my Stage 1 kit last night and I am blown away with how great this tune is. Hats off to you guys at Whipple, you've done a great job. The quality of these parts are next to none and the truck tune is unbelievable. Normal mode is woken up and Sport mode is a monster! Haven't had a chance to try out any more modes yet but I'm excited too!
jikjak
Canada
Forscan worked fine for me post Tune...
did the coolant/trans temp update today
Engine temp & Transmission temp shows above gauges (8" Clusters only) IPC 720-07-01 xxxx xE5x xxxx ** use this if you have trailer brake controller and turbos **
did you use the regular forscan program or the modified one?
jikjak
Canada
mad man
The best thing to do is try and blow up your truck I guess the Whipple tune isn’t enough. LOL
ray101381
Alexandria, VA.
So just noticed today while highway cruising around 80 my coolant temps seems to be fluctuating between around 205. I saw as high as 212. What’s everyone else seeing? I’m whipple stage 1 with the latest update.
Toadster
Toadster
Folsom, CA
I get to 210 but that's about it
Guy
The trucks are hot without a tune.
With a tune they are hotter.
You can bring those coolant numbers down about 10 degrees and stabilize the amount of fluctuating by adding Water Wetter to the radiator. 1 bottle.
Am I seriously saying that??? I did it on a whim months ago and it absolutely did the above.
10SpdsOfFury
Jacksonville FL
I use the Diesel water wetter in my work truck and it works great. The girl at water wetter said it is used a lot in the Middle East since the temps get in the 130’s and works really well.
