Ok I’m a little slow on electrical; the rocker setup, is that a new rocker panel and switches or do you run the rocker panel then wired into the switches? Or do I run a relay and fuse for each light/switch set. Only want to do it once but it seems I’m within the amp limit for each switch. I’m planning on tackling this project next weekend as long as the temps allow (no garage here).
Here is the setup I’m considering let me know if I have something misconstrued.
Switch 1 The radio runs 13 amp draw
Switch 2 The S8 30” bar runs at 12.12 amp so switch 2
Switch 3 The squadron racers are 2.9 amp draw(I think for the pair)
“ “ The squadron pro’s are the same 2.9 amp draw
“ “ The S2 pro’s run at 1.7 amp = 7.5 for the set all on switch 3
Switch 4 S2’s reverse lights 1.7 amp
Switch 5 1 S2 sport in 3rd brake light
Switch 6 2 S2 sports in 3rd brake light dust lights.
Thanks in advance!
the trail rocker universal kit sets you up so that everything is color coded. You simply run the trigger switch wires from the trail rocker to the hot aux leads under the hood. The trail rocker has a main power feed wire ( which it distributes to all circuits), then device power, device ground and it all buttons up nice and clean.
I'd be mindful of being that close to the max draw with the radio, the s8, and the squadrons/s2s. I usually load each circuit with no more than 60% of the rated max draw. I also use a minimum of 12Ga wire on everything. ( plus waterproof crimps on top of solders with braided wire loom covers. )
All of my wire, crimps, ends, and connections are marine grade with dielectric grease pumped into all connection points.
Even though BD draw ratings are what they are ( very low for the amount of light they put out), if you do not have some variance to the circuit ratings, as they get hot they could flicker a little, especially if you are using thinner gauge wires or your grounds are less than optimal.
I like the trail rocker because everything is color-coded and labeled. I built a custom setup myself for my first pass. tore it all out because the trailrocker setup is super neat and clean. If I had gone this route the first time, I would have saved myself about 10 hours of wiring. ( i have some circuits with resistors, dual power feeds and flasher modules on them).
As for the max circuit ratings without relays, IIRC they are 15a, 15a, 10a, 10a, 5a, 5a. i'd be concerned about 1,2 &3. 4 should be just fine. for 5 and 6, a pair of s2s should be fine.
And yes, before anyone says anything, I am overbuilt and play it extra safe with lighting and electronics. I personally have no desire to have to fix wiring issues or change fuses in the middle of nowhere, at night, when i need my lights.
