here is what I'm using: https://www.painlessperformance.com/wc/57100
I can take some pics of where mine is mounted once I bring my truck back home ( at the wrap joint right now).
I’m pretty sure in the Baja directions it said 30amp next to the lights in the instructions . I’ll do a little research and see what I can find but on the instruction sheet there was 30a on there [emoji23]Your math is off. 1x S2 Pro draws 1.7 amps. Sport draws 0.9A.
The whole 9 light KC Hilite pro roof bar only draws 15A. But I agree they should have just made the panel 6x30A.
Thanks for the tipPeople have recommended that you splice into the trailer plug centre wire as it is larger gauge than the side wires.
https://www.fordraptorforum.com/threads/baja-designs-s2-back-up-lights-install.55707/
