whats best dash cam and rear cam
BIGDJE
BIGDJE
OC, CALI
MDJAK
NY
Another vote for BlackVue. Doesn’t have to be the 4k though. I have both. Not huge difference.
WH7
Just installed BV 900 2 ch yesterday. Had the wrong size fuse tap so I have to wait a couple of days to make it hot. At least all the hard part is done. Had the BV 650 2 ch in my Super Duty. That one will go in the wife’s SUV.
RaptorMaryland
Maryland
I got the mini 0906, and just this week installed front, and back, with a parking mode power supply.
I ran the really long wire for the back camera to the right and down with the power supply cable, hids everything, then down to the passenger fuse box, and then back using the channel in the bottom of the door, the up to the rear window, and still had about a foot of cable left, even going the long route.
It has great reviews, and from 2 days of testing it just works as advertised.
https://www.amazon.com/Veckle-Chann...6&qid=1551062667&s=gateway&sr=8-3&tag=mh0b-20
Be sure to get memory and their
Parking Guard hardwire kit
Downside, is I found out in parking mode, only the front camera is recorded, when driving, front and rear are being recorded.
LeCreaux
San Antonio, Texas
My Dashcam is a Garmin DashCam55. Voice Activated, nice picture, great sound. Check out the link below to view an example. I think they have a 65 now. Probably a bit better, or more features.
I also run a Garmin DashCam55 front and back. I have them hardwired with the parking mode cable so they record any movement even when the ignition is off.
Gary E
Medford, Oregon
I also have the Garmin 55. It's very small and compact, smaller in size than a GoPro. The data card is very easy to remove as it's on the bottom of the camera.
RaptorMaryland
Maryland
My mini 0906 apparently interferes with the TPMS on the Ford F150.
So I am getting some Ferrite wrap around the wire snaps to see if that solves the problem of the TPMS telling me my left front tire is not being detected and sending me a warning message on the ford App.
Superman750
I am having the same exact issue with my Papago. I have tried some ferrite snap-on clips I got from Amazon and they didn’t work at all.
My next step is to try a different dashcam. I am going to try the street guardian. If you figure it out, please post what you did to fix it.
96,966
60,909
53vodich
Latest posts
