Cam phaser dilemma
97SHOGT
Anna, OH
They gave me an Escape too. I actually didn’t mind putting around in that for a week. Nice to drive something small in lieu of the truck and a Navigator L, but it was also nice to give it back…
Only other item I mentioned in my previous post is the valve covers. Yours might be okay, but my driver side was leaking where no oil should be leaking from and there was a hairline crack that seems to be a fairly common issue. Similar to all the other parts you mentioned, they already had it apart so I figured just throw new ones on. Mine was leaking towards the top of the valve cover above the oil filler tube. At first they said it was spillage from filling the oil. But unless the oil defied gravity, not to mention spilled up and under the engine cover, it was a leak…
M
mikemxbike4
Arizona
My driver's side valve cover has a hairline crack in exactly the same spot. I had mentioned to replace it to service writer. Hopefully they do. If not, I'm going to replace it myself.
Roush2568
Colorado
Mine has the same tiny hairline crack on drivers side. I'm going to try some epoxy this weekend, then maybe call Ford about fixing it under warranty if they have the valve cover in stock? I'm tired of smelling burning oil when the puddle gets big enough to drip on something hot.
I'm excited for you to get your truck back soon!
Kru
USA
That's the thing. I have yet to hear of a solid one in Phoenix area.
For what it's worth, the dealer in Apache Junction fixed my cam phaser problem with no issue. Realize, I am one data point but I had an extended warranty that they honored with very few questions. They also replaced my water pump while they were in there due to some noticeable seepage. While I can't guarantee your outcome, I wanted to share mine since you are local to my area.
Darkwhip
Tri Cities TN
UPDATE: picked the truck up today. Tech seems to have done a great job, and everything functions perfectly. Engine is super quiet and runs great. Engine compartment is spotless.
Super happy for you!! I was to paranoid over having mine done, then the sunroof broke. I just tradded it. So sad I loved that truck but the new one is great so far.
