Engine oil cooler line, I believe.
Where does the other end go? Into the rad?
@Yukon Joe
Run Raptor Run | Great Lakes Raptor Excursions (GLRE)
On the rad side you will need to remove it with a 5/8" or 3/4" line wrench (flare nut wrench). If it's the bottom hose on the rad, you'll want a plug or catch bucket under it. You'll probably lose about a 1/2 qt of oil as it drains out of the cooler.
Not sure how to remove on the engine side. But that can and everything will have to come off. No way to separate the rubber from the metal. The whole line needs to be replaced.
Are you sure the hose is leaking and its not something dripping onto it?
@Yukon Joe
That line comes from the compressor to the condenser. discharge line. you need to evacuate the ac system first before you remove.
