BangBang
- Joined
- Apr 2, 2018
- Posts
- 286
- Reaction score
- 151
He's a python. Just open a window and slither out!@JohnyPython How on earth did you park your truck in that garage like that and manage to open the door and get out?!
I agree 100%...only I'll ad to make sure the front wheels are chocked if there is any chance the veh can roll...I use a 3 ton floor jack under the rear differential, a whole other topic on its own, place jack stands under the rear axle and then move the floor jack to the frame rail indicator arrows behind each front tire.
I've only been in the Automotive repair industry since 1976..and in all that time never met a single person who jacked up from the rear diff and it caused any problems...the Raptor has a bad ass rear end so there should be no issues...I have heard so many different opinions about rear diff jacking it made my head spin; I ensure to stay cleay of the diff cover plate and use a 4x4 wooden block to protect the finish (rust) of my diff housing; its the only way short of a lift to get two jack stands as far apart in the rear as possible in order to remove both rear tires for a rotation.
Man that looks pretty sketchy...you have to apply a LOT of lift to get those wheels off the ground with all the down travel our trucks have...And yeah I do have the Big Wheel ProEagle floor jack...a little pricey buts its a monster for these lifted trucks...Lift the rear from the hitch
Swap in your spare and get 50k miles on ther first set of tires. I did.I've only been in the Automotive repair industry since 1976..and in all that time never met a single person who jacked up from the rear diff and it caused any problems...the Raptor has a bad ass rear end so there should be no issues...
Was waiting for people to chime in on whats a "proper" tire rotation...if I can I roll the rear drive tires straight forward, and cross the front tires as they go back to the rear...HOWEVER if you do some research you'll find it's about 50% as I stated above and the other 50% will say it's fine to simply swap the front and rear tires of each side...So I wouldn't lose any sleep either way...![]()
