What did you do to your Raptor today? (Gen2)
Jon_Solo
Jax
C1FFA58C-9F50-4039-A36C-2AC053F354B9.jpeg D8534905-2CC9-46B8-8C05-13F6B1F70E27.jpeg
Installed CVF Titan IC, Boomba adapter, and ADD Pro Bolt On v2.
Need to talk to ADD on Monday about the 2 bolts they include to replace in the IC mounting bracket. The instructions conveniently leave out the steps for holding up the IC while running the new bolts through the skid plate and mounting bracket.
PCDESERTstyle
Socal
Hello all,
I recently found this forum and was hoping someone could help me out. I'm installing baja designs light pocket kit and can't find the amp requirements to figure out if I have to use both 15 amp wires to run the 6 lights. If I run 4 lights on 15 amp, then I should be able to run the other 2 on a ten? Also has anyone played with which lights to group and which to put on second switch for the best results.
My rig 2019 Screw magnetic 802A carbon fiber and technology package. Eibach springs in front and whipple stage 1.
Thanks for the help
zombiekiller
OG BooBooRunner
New Orleans
Hello all,
Thanks for the help
did you get pro lights or sport lights? The amp draw is different between the two and may impact any guidance.
zombiekiller
OG BooBooRunner
New Orleans
the unlimted kit
each squadron pro will draw 3.33 Amps.
Depending on which upfitter you use, they can take 15A, 10A or 5A.
I like to plan for 30% buffer.
So for my porpoises, I'd say a pair of lights on 3 separate upfitters is the way to go.
I didn't see a spec sheet on the race versions of the lights, so I'd assume they draw 3.5 A or something close.
