Badgertits
Lol - yeah $50/hr hahahaCan you do my truck next?
With the AMSOIL, did you have to clean/prep area before spraying it on?
I pressure washed the undercarriage pretty good @ a car wash bay couple days prior, then took some rags & soapy warm water wiper everything down (didn’t soak it- just enough to get residual dirt off) then waited a bit for it to air dry & wiped any wet spots w/ dry rags & then did a quick blow down w/ compressed air. There was plenty of breeze too.
I hit up the diff/axles w/ wire brush & sandpaper then wiped down the residual dust/rust w/ tack cloth. Protected shocks/wheels w/ cut up paper grocery bags & drop cloths & sprayed the rustoleum.
Only thing I protected were the insides of wheels & shocks & lower A-arms when I sprayed the Amsoil- unless you’re 6+ beers deep you shouldn’t have a problem getting onto exterior paint/door panels, I got a little overspray on the wheel wells but wiped it up.
Also- found out the Amsoil HDMP is AWESOME @ cleaning/polishing the black exhaust tips & recovery hooks- sprayed a rag down w/ the Amsoil & wiped me down like I was using metal polish- check it out!
Lastly- when everything else was done I hit the shocks up w/ automotive clear coat to keep em from getting pitted/oxidized badly. I didn’t really care about overspray w/ that stuff
![DB75CF8D-2345-4693-89C7-BDA7D235C6CF.jpeg DB75CF8D-2345-4693-89C7-BDA7D235C6CF.jpeg](https://www.fordraptorforum.com/data/attachments/110/110812-5b5becb4e00077743a1313bff2a9c5e7.jpg)
