What did you do to your Gen 3 today?
TOMRAP
Florida
The front of the car was a little loose after the Einach's; now it's firm, the front points well when I turn, and the balance is much better. Drives responsive and sharp. Looks is the plus that you get.
You shouldn't notice a "differnce" at all....except how it looks. None of the componets @TOMRAP mentioned add any mechanical advantage except looks. They might add strength if anything, but even the tie rods are just 1/2 tie rod ends. The wink link is still the inner tie rod. The UCA's probably add some strength if anything. The geometry is the same.
After installing the Eibach Pro lift kit and the new wheels and tires, I noticed that the front of the car felt loose, and the caster was not within the proper specifications. The suspension was not working well. However, after the UCA and the Tie Rods, the front end feels more stable and balanced and now I have a perfect and funcional suspension. The car now handles turns much better, and the overall balance has improved significantly.
tone228
Maybe the springs threw the front out of alignment and when they installed the other components I assumed the shop aligned it again.
Waterfowler41
Illinois
FINALLY had a break in our hockey schedules to install the Sounds Good Stereo stealth subwoofer kit. This is a direct swap for the factory subwoofer. I dropped an install video in the How To section for those considering this kit.
Overall I’m glad I pulled the trigger sooner than later on the upgrade. This allowed me to pull back on the bass in the door speakers and use the new subs to take over giving me better low end fill.
