Wilson
South Dakota
I finally inistalled my PDP mud flaps. I've had them for over a year and was not sure I wanted to put them on. I liked the clean look of not having them. We are going on a road trip that will involve some gravel roads so I figured it was time to put them on. So far, I'm OK with how they look.
I also changed the oil and rotated the tires (the correct way!).
Wonder how it would look with color match and black lettering. Pic made me think of this.
Trick.Raptor
The Cracker Raptor
Santa Maria, CA
Installed my new running board extensions from @OFF-ROAD PERFORMANCE. Joshua was great to work with - responded to order, kept me updated with the progress and provided me shipping info.
Took about 20 minutes to install both sides (even without instructions - lol). There is a nice little piece of straight metal underneath the actual extensions that will hold a small mud flap, as well. That will happen another day and hopefully help keep out some of the mud and grime that finds it's way up under the running boards......
Thanks Joshua!!!
That looks good. My extensions are still in shipment and won't be here until 08/27... hopefully just these alone will cut down on some of the slop that gets on the sides of the Raptor.
2014RubyRed
Galesburg, IL
That looks good. My extensions are still in shipment and won't be here until 08/27... hopefully just these along will cut down on some of the slop that gets on the sides of the Raptor.
Just make sure you only slightly tighten the bottom two bolts, then tighten the side bolt. After the side is lined up like you want, then tighten the bottom two bolts up. I bent the side bolt bracket by over tightening the bottom bolts BEFORE the side bolt. You'll understand what I'm talking about when you first test fit them. Also check that little straight metal piece underneath. Great place to mount a mudflap....
The Macf
Vegas
Thanks Joshua!!!
Sweet pics.
cbcgeneral
Southeast Pennsylvania
Got this in the mail today from @Kmandoske and I can't wait till this weekend to install them. He did an awesome job on them and I would recommend him to anyone wanting to add more switches to your truck. Thanks Keith for the great service and bad ass switch panel.
