mprice1234
SVT Gen 1 Rules
Colorado Springs, CO
I just joined yesterday but so far i have done
- Fox 3.0
- 17x9 KMC IMS custom center caps
- 37x12.50R17 Nitto ridge graps
- Morimoto Headlights, tailights, mirror lights 3rd brake light
- ZZ2 apple car play kit
- custom painted rear emblem
- rocky mountain graphics front letters
Alot more to be done so will be posting more in the futureView attachment 474957
Welcome to the forum, nice Gen 1! Post your intro with a picture or two in the New Member Check-In thread to introduce yourself at the rest of the forum!
BenBB
Lots of different places
Mine has the same A3 that was in it when I bought it in '17 haha! I got the eternal "Navigation loading..." with the new ($22 from Amazon so slightly sketchy) B15 though so I'll try a master reset and update Sync again, hopefully yours works as advertised.
Master reset did the trick! And strangely none of my settings seem changed, but whatever it works and reads the B15 nav card no problem.
Got the new Powermaster starter but took a look and ugh, that top bolt is going to be a mother bear. Soaked all three bolts with penetrating oil, will wrangle all the socket extensions I can between me and bro and give it a go next weekend.
Went ahead and replaced the RH parking brake cable, the casing was split in two places and really rusty. Out with the old and in with the new (Raybestos from Amazon):
pat247
Oklahoma
Glad to hear the master reset workrd to clear the problem with the update. The map update should be huge going from A3 to B15.
BenBB
Did a headlight refresh with new lenses and swapped to a clear reflector in the headlight. Went to an LED bulb as well and so far so good, much brighter and thankfully no distortion of the light.
Looks great! I need to do the Meguiar's headlight renew again on mine, thinking I might try a clear PPF lens protector as someone suggested...
Bozz
Royal Smart A$$
Nashville, TN
Got seat cushion done. Wow what a difference, feels like i sit so much higher now LOL.
Stopped for lunch and got this for an appetizer. Candied bacon soo good
Hardee's has candied bacon right now, but it doesn't look ANYTHING like that! That stuff looks AWESOME! :p
DANG! Where is that???
MTF
Celebration, Florida
It depends on how much dirt/grime is built up in the window tracks and when was the last time you lubed the tracks and cables with wire rope lube?
Motocycle/bicycle chain lube will work too, you just need to use the right lube that will not let dirt stick.
