Bozz
Royal Smart A$$
Nashville, TN
Anyone who is in the Lake Hartwell area, I need help figuring out what is going on with my truck. It started immediately after filling up with gas. I had misfires on cylinder two, now on at least one, two and four. I’m truly desperate and grateful for any help.
Vapor Canister Purge Solenoid Control Valve?​
TomDirt
Hesperia CA
I got stupid and tried to unload the 6r80 alone. Did I mention it's listed as 215lbs?Anyway, I dropped the bitch and cracked a piece of the housing; also dented the pan. The neighbor is coming over so I can flip it over and lift it up on a bench to check everything. If I have to, I'll get it welded back on. Option #2 is bolt it up, then JBWeld it in place and send it.
JB weld saves all! I'll let this area set, then apply more to both edges & inside. It's rated to 600°F, so unless the trans catches on fire it should be good.
badm0t0rfinger
Rocket Man
The Beach
@TomDirt I was going to suggest JB weld when you first posted but didn't want to offend.. I fixed a jet ski Block that got a window in it with it...( 2 stroke) Put 100 hours on it ran when I sold it. I think you will be fine.
That sounds like either Yamaha 701 or SeaDoo 717 engine. Both of those were insanely hearty. Kawasaki had the 750 and 800 too, but those were more about power than brute durability.
Gumby
Nashville
@badm0t0rfinger yes a Yamaha the auto oil injection failed. (so the guy said) broke the rod punched through the bottom of the case. Last ditch.... put some painters tape on the inside build up the outside up with JB weld put it back together rode it for 2 summers ( well the kids did)
badm0t0rfinger
Rocket Man
The Beach
I love those old 2 stroke engines. They could blow up and be put together in a weekend with some ingenuity.
