laselvasurf
Santa Cruz, CA
I replaced the sunroof switch as the rear slider window stopped working. It was a super easy job, less than 10 minutes and it fixed the rear window problem.
At this point I was feeling pretty good, so I thought I'd see if the sunroof worked as well. The PO told me it was intermittent and he just never used it. I tried the tilt first and it was solid. Then the slide button and it worked! Super stoked... I then tried to close it... Lots of grinding and crunching sounds ensued and the glass retreated back to the fully open position. After messing with it for about 45 minutes I wasn't able to get it fully closed so I decided to just replace the tracks. Luckily I bought the dr. sunroof kit back when I picked the truck up as I knew the sunroof was an issue.
I'm sure many others have done this job, so I won't rattle on about it... In short I started at 4, had to stop at 8PM as it was dark and wet out. Luckily I had gotten to the point that the sunroof assembly could be reinstalled, so I did that and temporarily installed the glass to keep things dry overnight. I then started again at 8AM and was done by 10 this morning. I followed the youtube tutorial and all in all it's a very easy job, just quite time consuming.
After getting the interior all back together I installed a console safe I bought through FB marketplace for $80.
Chiefapple
Milwaukee, WI
Anyone have the part number for belt and pulleys? I hear a squeak, so may as well do it all at once. Just not sure what the kit number is.
Deleted member 12951
Guest
Was doing a little organizing
What is to the right of the portable jack
What is this?1f14bd27cd5d9416d75acb59b24e76ed.jpg2070057a48a8bf7abfac9a38e34726d8.jpg
Sent from my SM-G991U using Tapatalk
It's a jack extension. The jack that is in there on the left is the normal jack in all F-150's. The extension is used for the Raptor due to needing to get the truck higher due to its suspension travel. Sounds like you never have had to use it, so that is a good thing. :)
RC51TOFUMAN
in Thee OC
Hey fellas
I am getting my Rebuilt OEM shocks installed tomorrow at SVC. Anything I should ask them to check while they are swapping out my shocks?
I've got 98k on the odometer if that matters. 2013
You're knowledge and replies are appreciated in advance
