allinon72
Indianapolis, IN
Installed Corsa Extreme - man what a noise this thing makes. Also quiet when you want it to be. It was actually a joy to install on the ground without a lift, unlike some exhausts I've done that required endless back breaking tweaks to get right.
Angelo1
Nashville, TN Atherton, CA
View attachment 132584 View attachment 132585
Please Upload sound clips on startup,idle and giving it some gas
Jakenbake
Installed new front shocks with Geiser springs. Will grab pictures tomorrow and new measurements but pre-suspension settle netted me over +2”.
Truck rides pretty good. Makes me wonder if it is the spring swap or the new shocks that are making the bigger difference. I had 40k on the factory shocks but it appears that the truck has never been off-roaded.
SZDZMTR
Sewell, NJ
Had one the FRF members, Ryan Heinemann, fabricate a custom bed cage to hold two tires, proeagle jack, compressor and air tank for the train horn...excellent work, there is room for Bodies too....28afe05640f0b8091bff1631df8fd1cc.jpgdd85a36cd7b116febbed7371dee2861f.jpg
Sent from my SM-G960U using Tapatalk
JefeAZ
Tucson
Just drove on I-10 from Phoenix to Tucson and several times it felt like I was driving over a cattle guard for a long stretch of road. I've driven it a ton of times and never noticed this. I slowed down below 70 and it would stop a couple of the times but I couldn't repeat it the others. It was fairly violent and shook the truck pretty bad. Think I need to take it in for an alignment, something might be coming loose. 10K miles on the tires. I did install new lug nuts and re-torqued them to 150 before the trip. Ill check those again
Saturday I started the truck up and the engine free rev'd while in park and my check engine light came on. I put it in drive and started rolling, hit the gas and had nothing. No response no matter how much pressure I put on the pedal. Pulled over, unhooked the battery for 5 mins, hooked it back up and all was fine. Never did it again. I have a pedal commander installed and need to check the connection but could it be killing the throttle sensor? I really dont want to remove the pedal commander
Also just noticed the 3 red lights in the 3rd brake light went out. Fun weekend
Chiefapple
Milwaukee, WI
I would blame the pedal commander for your throttle issues... plenty of stories out there of them causing problems.
Mine would rev the engine if I tried using the vhf radio. Glad I found that out in park in the driveway rather than on a trail during a run.
