CoronaRaptor
You mean like get stuck on the way to the mall?Im going to get shit no matter what i do soooooo, no biggie lol
@kromealt
Not yet, I was planning on trying a VP Race jug from amazon
VP was the one I want to go with, but appears to be an inch too wide on each side. It may shove down in there. Please let me know if you order one. Thanks, Matt
External speaker for the ICOM? Is the sound muffled much with the console closed?
I hope you installed that antenna at least 18"'s from the back light. It needs at least 18" for a proper ground plane to get the 3dB boost
Only tested from handheld to truck at home. No external speaker yet, going to test at Rip 2 Strip next weekend.
---------- Post added at 11:32 AM ---------- Previous post was at 11:20 AM ----------
No. I got the chase package and it came with the 3dB antenna. I called PCI about possible change to no ground plane to install on bed rail.
Guy I talked to at PCI had a Raptor also and said center of roof is best, you loose some at spot by third brake light but he tested and said not too much. He did say height did have a significant effect and highly recommended on roof instead of bed rail. He had his at third brake light spot and gets great range and doesn't use rain cap when antenna is off and never had a leak in any vehicle over many years.
The install is super easy at that location and realizing the factory GPS antenna goes through a hole in roof and doesn't leak. The first cut is always the hardest.
I already have that antenna on my roof, but I installed it to get the 3dB boost. That antenna with out the groundplane will act as a normal 0dB gain antenna
according to PCTel who makes it
Wow, I have renewed respect for you, lolHad my own version of Snoball. It was absolutely terrifying all of the roads are hills and one of them had snow up and over the running boards.
