jackrook
Did I get it done or what???? My clip couldn't fit in the hole. So I made a hole. Get over it. LOL
Sure thing boss. You realize u said u drilled a hole 3/4 when the hole I told you was 3/4(hint small hole) but then posted a different pic with a bigger hole and then said I was no help when you texted all day. Do me a favor and find help somewhere else if you don't know how to use the word thanks. Sent from my SCH-I545 using Tapatalk
I made it.
Took a standard network wall jack and dermeled it down to fit. Used a RJ-45 coupler to attach it to the keystone plate. Had to cut a hole in the console, but it was t that bad.
So the microphone jack is the same wiring and everything as an ethernet jack?
Same jack? Also, how is the jack/wallplate secured to the console?
Can this scenario be set up with a splitter? If I have a co-driver with - have the same jack on the other side of the console as well and then plug microphone in on the side needing it during that time. I understand the cord will reach but just saying.
It will work, just don't key both at the same time or the people on the other end won't know whats going on lol
Thanks guys. Installing the VHF tonight
Sent from my iPhone using Forum Runner
