VHF radio install pic's
RaptorScrew
Oronoco, MN
Yes it is only vhf radio
Sent from my SAMSUNG-SGH-I537 using Tapatalk
Honestly, do you notice any difference in the normal play of music without that center speaker being used?
...I like your idea of dedicating that speaker for the VHF. I'm sure there is a way to connect a quick disconnect so that when you're not using the radio you can go in and switch back to nav/radio...
manny
San Jose Ca
I would suggest you disconnect the speaker for a few days and determine if you can how much the difference is and if you can live with it
If you decide you can't live with it disconnected then you might wanna contact Noah from the car stereo company and see if he can help you with installing some kind of switch to go back n forth
jackrook
Bermuda Dunes, Ca
Here's my Icom installed. Sent from my iPhone using Tapatalk - now Free ---------- Post added at 01:08 AM ---------- Previous post was at 01:07 AM ---------- Sent from my iPhone using Tapatalk - now Free
I did the same thing except I mounted my mic clip on the drivers side. Easier for me when riding solo. When I've got a passenger, we can just keep it in the cup
Sent from my iPhone using Forum Runner
jackrook
Bermuda Dunes, Ca
Icom F5021 with permanent mount antenna install
so any time you go on an "official" Raptor run(Snoball, Havoc, TRR, etc) you are pretty much dead in the water unless you have a VHF radio. a popular choice is the Icom f5021. simple and easy to use. as a rookie, i went to a ham radio store and they ripped me a new *******. they wouldnt help me because i didnt have a "callsign" and wasnt licensed. they had this exclusive attitude. so you know what? **** YOU!!! i bought it off the internet and it was cheaper!!! i also got a 50 inch Larsen half wave antenna with a NMO mount. i got the standard 17 feet of coax cable that runs from the antenna to the radio. i also got a rain cap that can be used to cap the antenna mount when not off roading(ex, daily driving use).
lets get started.
first thing to do is remove the two screws hoklding the rear brake light in place. then just gently remove the brake light and let it hang but the connections. itll be fine.(thats my GFs yummy ass in the reflection)
next, gently pull back the headliner until you can sneak a peek at the brake light opening. once you can see it, thead the coax cable through the brake light opening.
now push the cable all the way to the back of the roof to where it meets the back window. the cable cleanly tucks away into the back side panel all the way down. just finger tuck it in as much as you can. its not gonna pop out.
heres the wire peeking out behind the back seat. i purposely took the picture with the wire exposed so youll know where to tuck it. so tuck it in down the panel and make your way to the floor.
heres the cable peeking out of the back and front door sills(pictures were taken with wire out on purpose). continue to tuck wire under door sill and carpet. you will be fine. its easy.
the front door sill(just like the back) pops off completely. its held in by clips(which ive broke but that just gave me an excuse to get the recon illuminated door sill LOL). completely remove the door sill and left up the carpet. run the coax cable across, under the carpet towards the center console.
now heres where im gonna get a lot of heat from people but i really dont care. i cut a small hole in the carpet to pull the coax cable through. dont like it? drill a hole in your center console. either way youre gonna need to either cut or drill. i just tore up the carpet...just like i do in real life LOL
GREAT!!!!! the coax/antenna cable is in. now lets mount the antenna.
going back to the first picture of the opened third brake light, we find the perfect mounting area for our antenna. unfortunately i couldnt take pictures while drilling the hole but i made a 3/4 inch hole, 2 inches from the brake light, slightly off center(i wanted my antenna to have some personality).
its literally that easy. i understand some of you may be uneasy about drilling in to your roof, but have confidence. there is no wiring back here and its relatively thin.
heres a picture of the ACTUAL rear end of the coax cable where the antenna attaches to. once i tightened the ring that keeps the antenna in place, i applied a thin layer of black sealant just for some extra protection. i didnt really care what it looked like because whos gonna be inspecting the roof of my truck for sealant residue??
heres a picture of my Larsen antenna mount with the antenna in it. you have to open the mount with a tiny allen wrench(supplied) and slide the antenna in then lock the screws with said allen wrench.
heres the full antenna(wires in the background are 20ft high. dont worry)
and here is the raincap/cover that is used when the antenna is not on. this will be kept on for my daily driving. it protects the pieces of the coax cable mount that accepts the antenna and screws on.
AWESOME!!!!!! now that weve got the coax cable ran and the antenna mounted, lets run the power cable!!!
pop the hood and look to the fuse box in the back left corner. just under that is a rubber plug. what a coincidence...i took a picture of it.
now comes for the hardest part of the install!!!! remove the rubber plug. it took me 7 beers to work up the confidence to do it, but i did. i manned up and pulled it out!!! behind it is the firewall.
i tried and tried and tried and tried and tried and had no success. i was in constant communication with SVTdon and still couldnt get it(like hes any help LOL). so i finally said **** IT!!! so i pulled back the carpet and found a spot that had to wiring or vital components on either side of the metal.
i drilled a hole using a 3/4 inch bit. i drilled the hole to give me about 3 inches of protection with the wheel well. the wheel well is relatively hard and will prevent mud, water, etc from getting in to the hole. heres the view of the hole from the engine.
heres a view of the hole from the inside, behind the carpet and firewall.
now that youve got the hard part over with, we can connect the cables to the batter. black to black and red to red.. once youve connected it, be sure to tuck away the cable so it doesnt get chopped or burned up.you wanna have SOME slack so youre not damaging the connectors. hide the wire and feed the excess through the hole, into the cab of the truck, like so...
now that i have the cable inside the cab and the carpet lifted, im gonna run the power cord through the same carpet hole as the coax cable.
my actual radio is being programmed by Icecobra. you may have purchased your radio already programmed or have a radio that doesnt need programming. thats all good. while my unit is being programmed, lets finish this write up with the MIC MOUNT.
it is suggest to "ground" your mic mount if you plan on using your radio to "scan". however, with an f5021 Icom, we cant scan. all ofo out stations need to be programmed. so theres no need to ground it.
i picked the drivers side so that way, if im riding solo, i wont have to reach over to the passenger side to grab the mic. when i have a passenger and they are controlling the mic, they can just keep it in the cupholder.
here it is mounted and with the mic on it. im 6'6 and have PLENTY of leg room. this is nowhere close to hitting my knee.
I WILL UPDATE THIS POST WHEN I GET MY RADIO BACK FROM BEING PROGRAMMED.
MajorAR
Kansas
That's a great write up bro! Thanks for sharing.
Will you have your radio back before this Saturday?
SvtDon
San Diego Ca
{snip}
YOURS.....
MINE! I TOLD YOU REALLY SMALL HOLE UNDER THE ROUND PART ON THE SIDE AS YOU CAN SEE MY WIRE! MY WAY IS PREVENTING AN EXTRA HOLE BEING DRILLED WHEN THERE ALREADY IS ONE STOCK!!!
Not sure how u got your hole from my picture!
