VelociRaptor 600 Raptor burnt to ashes...
O
Omani-Raptor
Oman
Easy with the insurance fraud stuff guys. Even suggesting such things can be criminal in some jurisdictions.
I live +10k miles away from you guys , don't worry I'm not gonna report anything...
I'm open for any ideas to share with my friend
chartguy
Reasons unknown as of yet
but lets discuss ? Detonation? Air/fuel mix problem?
I've been a volunteer firefighter for about ten years. Most of the car fires that I've responded to have involved turbocharged engines, typically factory turbos, not aftermarket ones. The reasons are simple. The turbo compresses air, so the engine can burn more fuel (produce more power). That means that the fuel pump and injection system are higher capacity. Because it's compressing air, the turbo(s) get hot. Heat cycles can loosen compression fittings. They get hot enough to ignite gasoline. Combine a hot turbo with a leak in a high-flow fuel injection system, and you get an intense fire.
I am NOT saying that happened here. That will take an examination of the remains by someone who knows what he is doing. I am saying that's the most common cause of car fires that I've dealt with as a fireman — fuel leaks in turbocharged vehicles.
Hookup
Socal
Im so sorry man :whymewhyme: I heard hennessy has had a problems with their superchargers blowing up. Was gunna get the 775 before they took that off the kits along with the 900TT package and the 500. Really sorry man.
SPRSNK
I Void Warranties
Franklin, TN
They are simply ProCharger's with a Hennessey cover.
