Validation for 5k Oil Change Intervals
DFS
USA
So as someone isn't versed in oils, lubrications, or the finer details of engine preventative maintenance, I'm guessing I'm relatively safe with the following SOP:
5,000 mile intervals AMSOIL Signature 5W-30 and OEM Oil Filter? Most of this debate seems far more nuanced than may be beneficial for the average owner and really digging into the minutiae so looking for a dumbed down answer.
nikhsub1
nikhsub1
Los Angeles
For anyone reading this thread getting confused and just want the 'WTF should I do' short version...
1. Use quality full synthetic oil - don't use blend IDGAF what the manual says
2. Use a quality filter - OEM FL500 is fine
3. Change the oil every 5k miles if you want the motor to last a long while
New recaros
Colorado
Absolutely correct.
EricM
OHIO
Yea, but you could save a lot of money running Walmart Supertech instead.
Amsoil is great oil, but $15+ a qt oil is not needed for any production engine.
If I am dumping it every 5K miles, I'm not using running $15+ a quart oil.
New recaros
Colorado
I thought you had money to burn!
EricM
OHIO
If I have money to burn, I don't spend it on high end motor oils.
I prefer to spend it on tangible things that last.
