Upgrading stock OEM trans cooler
hedonist222
Dubai, Abu Dhabi, UAE
guys just a question
from left to right:
oil pressure
coolant temp - coolant
fuel
transmission temp
right?
Coolant cools the engine block? Only? Not the transmission block as well?
And transmission gauge from photo, thats the transmission oil temp?
thanks!
BenBB
Lots of different places
from left to right:
oil pressure
fuel
transmission temp
right?
thanks!
Yes exactly. Out of curiosity, what transmission temperatures do you normally see on a Gen2?
Dane
Littleton, CO
from left to right:
oil pressure
fuel
transmission temp
right?
thanks!
Yup! The transmission fluid is cooled by the transmission cooler. Assuming it looks the same in the Gen 2, it looks like a tiny radiator in front of the actual radiator. There's also some cooling effect from the excess fluid sitting in the pan. This is why you'll see some aftermarket pans (AFE) with cooling fins and extra capacity. The cooled fluid is pumped vertically up from the pan into the transmission, while hot fluid is pumped to the transmission cooler and back to the pan. Very similar concept to the radiator, but different fluid and different system.
Raptized
Raptorida
A pipe runs to and from this plate with oil circulating through the plate.
Sent from my SM-N950U using Tapatalk
