I see the 6,000 # of pressure dose any one know how many # of pressure the current IWE has?
Electric PTO Clutches
Find your
Electric Clutch below. When you need a
PTO Clutch that is adjustment and maintenance free and designed for rugged use and still delivers high performance, then try Jack’s first! The type of
Electric PTO Clutch we carry also clamps down with 6,000 lbs. of pressure. Whether you need a Small Engine Clutch or a Lawn Mower Clutch, we have you covered. To find the correct
Electric Clutch, locate your manufacturer then part number to find the
PTO Clutch you need.
---------- Post added at 03:16 PM ---------- Previous post was at 03:08 PM ----------
I got it about 22psi
---------- Post added at 03:21 PM ---------- Previous post was at 03:16 PM ----------
Lawn Mower Wheelie - 8 Horse Power Modified MTD Wizzard with Craftsman Axle - YouTube
---------- Post added at 03:34 PM ---------- Previous post was at 03:21 PM ----------
Other types of electromagnetic clutches
[edit] Multiple disk clutches
Introduction – Multiple disk clutches are used to deliver extremely high torque in a relatively small space. These clutches can be used dry or wet (oil bath). Running the clutches in an oil bath also greatly increases the heat dissipation capability, which makes them ideally suited for multiple speed gear boxes and machine tool applications.
How it works – Multiple disk clutches operate via an electrical actuation but transmit torque mechanically. When current is applied through the clutch coil, the coil becomes an electromagnet and produces magnetic lines of flux. These lines of flux are transferred through the small air gap between the field and the rotor. The rotor portion of the clutch becomes magnetized and sets up a magnetic loop, which attracts both the armature and friction disks. The attraction of the armature compresses (squeezes) the friction disks, transferring the torque from the in inner driver to the out disks. The output disks are connected to a gear, coupling, or pulley via drive cup. The clutch slips until the input and output RPMs are matched. This happens relatively quickly typically (.2 - 2 sec).
When the current is removed from the clutch, the armature is free to turn with the shaft. Springs hold the friction disks away from each other, so there is no contact when the clutch is not engaged, creating a minimal amount of drag.
