Upgraded IWE
If a full time hub was available for the Raptor would you upgrade?
  • Total voters
    163
MTUH3
Plymouth, MI
42,000 miles and mine is still going strong.
2011, no Torsen
All the time locked hubs are will not cause a significant increase in the need to service CV joints and boots IMO. I own one vehicle that is all time 4 wheel drive and only only replaced the CV axles once, as precautionary measures while upgrading. Original CVs are fine after 70,000 miles. Personally, I would love to take the torque transfer transfer case out this truck and put it in the Raptor, giving the Raptor all time 4x4. It wold simplify the hub and CV axle servicing.
Yukon Joe
Trafford, PA
I wanted to put up poll to gauge the interest in an upgrade IWE.
What I am planning it to strip all the guts out of the IWE removing the spring/vacuum parts/and flimsy 1/4 gear ring with a solid gear ring. This would cause the front axle to be locked at the hubs and no more shearing/rounding the teeth off the IWE gear ring. There would be more noise, loss of fuel economy (figure 1 or 2 mpg), and wear on tires and drivetrain.. The benefits would be fully locked hubs, no slipping or clunking, no vacuum lines, vacuum solenoids, or check valves to fail..
I do not have final design of the uprade IWE yet, I am working on it. I do not know what long term effects to drivetrain or axles. This is just in the idea stages right now..
What's this I hear there is a fix coming? Something about a locked IWE?
Need the 411
Yukon Joe
www.RUNRAPTORRUN.com
Dv8tor
Detroit, MI
I'm not sure what's going on with this. Haven't seen a lot of Greg floating around here on the forum. Hope everything is going well.
Wilson
South Dakota
