UPDATE-2-25-22–The Dreaded ORANGE WRENCH DISPLAYED-
John M BUNMAN
BUNMAN-Adventures, Rescue & Recovery
Las Vegas NV
@FordTechOne i need your help brother.
I got the dreaded ORANGE WRENCH today. I was out running errands. Went in an office 10min, came out and started the truck. Dash was blank, NAV/info screen completely blank, back power windows worked, front windows would not, no back up camera.
I drove it about a 1/10th of a mile and the dash and NAV screen came back on, Along with the ORANGE WRENCH-check manual-hill start/descent disabled. Started truck after it sat in the driveway 20 minutes, wrench gone.
NOTE- I have been running the tires at 30/31 for the last few days which of course triggered the Low Tire Pressure warning. Could the truck possibly be pizzed off that I haven’t aired the tires up?
I have a call into service to see if they want it brought in or if it can wait 1k miles until the oil change?
Your thoughts Sir?
Update #1. Air the tires up a bit, drive it around about 20 miles, no wrench, no other issues detected.
Talked to the service manager, I’m bringing it in Friday doing the 40k service early and checking for any codes. He thinks as I first thought “BATTERY” I have never gotten more than 3yrs out of a Battery in Las Vegas, heat kills.
I have read a few other places, here and elsewhere, anything from a gasket in the diff, to a $4k repair?
I don’t have a good battery tester just a cheap one and it’s showing 11.9-12.3 amp’s but it doesn’t test cold crank amps etc. So it’s basically worthless.
Friday they will test it properly and hopefully that’s it and they will warranty out the battery.
I’ve see on here some folks putting theirs on a trickle charge a couple times a week?
Raptor 2019, bought 11/2019, 39k miles, serviced at Ford every 5k, stock except for some BD lights.
Thankfully ESP, as always.
As Always THANK YOU in advance, your advice and guidance is Always appreciated on here by me and everyone else.
I will update after Friday
John M BUNMAN
John M BUNMAN
Las Vegas NV
Sounds like a battery to me, interested to know what they find. Better stay close to home brother in the meantime, just in case.
In the past, on the 240k miles on my Gen-1’s, the first sign of battery issues was a slight hesitation when starting. Now I have no idea because the thing is a giant computer on wheels. Interested to find out if the first indication of battery issues on the Gen-2 is …it looses it Fning mind and acts possessed :devilfinger::devilfinger:
THANKFULLY, the Slow-Lube Manager is an Ordained Minister and is licensed to preform any and all Exorcism’s that my be needed :angels2::angels2::angels2:
I’ve never seen the TPMS be “a thing” anything more than having to air up.
I’ve also never killed a battery that quick. Well... Unless you count the Ducati but that was because the voltage regulator got cooked, which cooked the battery...
Good first guess.
Got Forscan? pull some codes and see what’s what
John M BUNMAN
John M BUNMAN
Las Vegas NV
Good luck man! I had a similar issue with my truck when I took it up in elevation while towing. They reflashed my shit and everything worked fine since. Ps this is the gen 3 section ;)
Like I’m supposed to actually know where I’m posting?? Lol
sorry thought it was just general discussion..
maybe @Shaggy can move it?
John M BUNMAN
John M BUNMAN
Las Vegas NV
Good first guess.
Forscan?? Ummm that’s kind of a personal question isn’t it? That’s between me and my doctors, I think it’s a Hippo violation even talking about it!
But no, I’m clueless on how to use it. :banghead:
GCATX
King Dingaling
Central Texas
Over the 3.5 years I've owned my 18, there have been a handful of times random gremlins have popped up, only to be solved by restarting the truck. I chalk it up to the Raptor mystique. I am sure others have similar stories.
I wouldn't take it to the dealer unless it's an ongoing issue. Just me though.
