UnderCover Swing Case
BearLeeAsian
Dallas Texas
Thanks to ford.. This install is going to take much longer than expected. Can't seem to remove the ford Bedliner / torx 30 screw.
Thinking about mounting directly over the strapping point.. Thoughts?
BearLeeAsian
Dallas Texas
They are good. Minus the fact that I couldn't remove OEM mounting points due to fords spray in Bedliner...
Oh and the driver sides bracket is a little loose but can't really tell when it's mounted. So far love them. Install was just a PITA
jkscuba
Yeah saw the pic. Does look like a pain. End result looks good though.
BearLeeAsian
Dallas Texas
Doesn't sit all the way on the bed but I don't think it will be an issue. Don't plan on putting 70lbs of stuff in each one anyways. Thanks again for a good deal. Left you a positive feedback in the classifieds feedback section
Badrap
Mabank, Texas
I use the tie down to run a ratchet strap thru to hold them in place when off roading. Get some foam to pack in there and you are good to go.
BearLeeAsian
Dallas Texas
You mean you wrapped a tie down around the case? I plan on running a lock on each one since I do not have a cover...
Badrap
Mabank, Texas
Not a tie down but a strap. They will get loose after hard off-roading. Did you use bolts or lags to mount?
