The Hub and actuator/IWE were probably both replaced. That's where the extra cost came from. Glad its all taken care of.
An f150 came through the shop yesterday with a IWE/hub problem. This one had water intrusion in the IWE. Took some pictures.
These are the IWE. New one is the one with the green grease. Its basically a diaphragm that moves a toothed locking collar in and out. The locking collar is part of the IWE.
Close up
These are the splines on the CV shaft stub. These splines stay in constant mesh with the locking collar. The collar will slide back and forth about 1/8 of an inch during 2wd to 4wd on these splines. Since they're always in mesh, and very tough, these splines rarely (from what I've seen) go bad when a IWE goes a whack.
Close up of the Hub splines/teeth. Not a good picture, but these are the teeth the locking collar will engage with when going to 4wd. These are the teeth that round of during IWE failure which results in needing a new hub assembly. The teeth need to be sharp for clean engagement. These were rounded off enough to need hub replacment. The teeth on the locking collar also round off.
Better picture
