BigJ
- Joined
- Aug 5, 2010
- Posts
- 5,448
- Reaction score
- 1,561
No. Good point. I have the right line, yes? And should I start in 2wd, or 4wd, or does it not matter?Did you try your vacuum line test on both sides?
If you jack it up, with the engine off/no vacuum going to the hub, the hub should be locked spinning the cb axle when you spin the wheel. With the engine running/with vacuum to the hub, the hub should unlock allowing the tire to spin without spinning the cv shaft. If you can get all four wheels jacked up and safely crawl under it, try locating the noise from the bottom with the truck in two wheel drive running in drive.
---------- Post added at 01:45 PM ---------- Previous post was at 01:42 PM ----------
Yeah right line. Shouldn't matter what setting you start in. Defualt is hubs locked with no vacuum. They do this so you have 4x4 if you loose a line or vacuum. Fords hubs are kinda junk to begin with though so if its hub related it doesn't surprise me.
It may have damaged the hub enough to need a hub and actuator.
Would the ends of the half-shaft ( splines? ) be affected, also?
Is far as I know there are no upgrades on the market but honestly I've never really looked for any. The actuator and hub will be seperate components. Your truck may only need the actuator. The hub might still be ok but that grinding/clicking noise is the teeth rounding away which affects how it engages.
---------- Post added at 02:38 PM ---------- Previous post was at 02:35 PM ----------
No they should be fine. Luckily the hubs good at destroying only itself lol.
