Treypal's 2014 SCAB Build aka The Texas Raptor
treypal
treypal
Lord of the Raptors
Riviera TX
Quick review on the Total Chaos parts and Kings.
Everything worked great at CRR. I did have some bolts come untorqued but it was all my own fault for rushing the install. FYI the lower shock bolt is a M20 1.5 pitch... The Kings work AWESOME, however you have to drive them pretty hard, which is ok with me. The Total Chaos arms performed flawlessly as to be expected, I'm happy with the poly bushings on the frame side of the arms, less heims to replace.
The truck is parked for a bit while we move to a new house with the best mod possible for a Raptor. A 30x50 Shop!
The Car Stereo Company
here, on frf
great. now i have a place to do installs when im out you way
treypal
treypal
Lord of the Raptors
Riviera TX
Any guesses?
Juncle
San Diego
LCA and bypass from Total Chaos?
Question - looks like the Total Chaos UCA works with stock beadlocks - no rubbing?
pat'sRAPTOR
Everywhere
no the tops don't seem to rub but the LCA's are rubbing pretty bad cutting into the rim. the stock beadlocks weren't out when they tested their LCA's so they couldn't check for clearance till now.
treypal
treypal
Lord of the Raptors
Riviera TX
UCAs are no issue. As pat said, they hadn't tested the lowers with factory beadlocks. The inside of the casting has a little more lip, so TC is disclaiming that they won't work with factory beadlocks, although mine have since clearanced themselves out.
