When you pull up the tire pressures on the dash do you see a reading for all tires? I’ve had it happen a handful of times where the sensors would go offline and I’d get a TPMS error message. It seems to come back on by itself after a bit for me. When it does the low pressure warning will go away by itself.Sorry, not trying to hijack this thread, it's just that it's current and many people may look at it.....
I do NOT have the TPMS sensors installed in my wheels, but dash low-tire-pressure warning has come on and won't go away. It was not there for the first year I drove the truck. Again, no sensors installed, have tried to find a way to delete/reset warning, but coming up empty. Anyone? Thanks.
I will have to look at that. I've never seen any tire pressure readings listed anywhere, just that warning notice.When you pull up the tire pressures on the dash do you see a reading for all tires? I’ve had it happen a handful of times where the sensors would go offline and I’d get a TPMS error message. It seems to come back on by itself after a bit for me. When it does the low pressure warning will go away by itself.
Is this currently working on a Gen 3 raptor? or is yours a 2020? I just got my 5 wheels in the mail today and I want to get them mounted and balanced and order the TPMS sensor. Want to double check before I order the TPMS sensor that the 5 tire rotation is working and the vehcile automatically detects the new TPMS. I understand it can only read 4 at a time and I'm not concerned with a reading on the spare tire, but I would like it all to work once I rotate the 5th into the mix.Adding one to the spare is a good idea. Didn't think of that.
Just ordered a set of 4 OEM Ford TPMS sensors for a new set of wheels. Called 2 places and they both gave me the same answer on part number for my VIN (see below). Got the sensors in 2 days from one of them online and they have 315mhz on the sensor. This matches what Tire Rack provided for a 2020 Ford Raptor (I don't think their compatibility search was updated with 2021 yet). Haven't installed yet, waiting on the wheels and tires.
What I ordered.
Short part number: TPMS-68
Long part number: ML3Z-1A189-B
I don't see that feature anywhere on my menu. Just get a warning notice.When you pull up the tire pressures on the dash do you see a reading for all tires? I’ve had it happen a handful of times where the sensors would go offline and I’d get a TPMS error message. It seems to come back on by itself after a bit for me. When it does the low pressure warning will go away by itself.
Hit the menu button on the steering wheel. I think it’s in Raptor Info. Use the arrows to scroll through the different pages. It’s after then”measurements” page.I don't see that feature anywhere on my menu. Just get a warning notice.
