Disclaimer: Links on this page pointing
to Amazon, eBay and other sites may include affiliate code. If you click them and
make a purchase, we may earn a small commission.
You could use a set of SuperSprings for those temporary jobs.
Twenty minutes to put on or take off. It's a tapered helper leaf spring.
They'll raise the back of the truck about an inch and a half.
And no "torque wrap".
I'm getting an 8500 lb avion trailer as a hand me down from my grandfather (Similar to airstreams). I plan on gutting and remodeling it and will hopefully be able to put it on a diet. But if I wanted to increase my towing capacity what should I be looking at?
Is the gearing the weakest point? Or is it the softer suspension that can't hold the weight? I would assume that the 6.2 wouldn't need many if any modifications to pull the trailer. Tried searching the raptor forums but didn't come up with much.
I live in Colorado and pull a 7500lb travel trailer in the mountains with mine. I use a weight distributing hitch, Hellwig helper springs and installed the SDHQ transmission cooler. Truck sits level and pulls like a charm!
