rmarquette
- Joined
- Apr 28, 2017
- Posts
- 6
- Reaction score
- 5
To the OP:
Where you using Tow mode?
What gear and rpm where running?
Sometimes manually dropping a gear will let the eng run easier and might get a little better mileage...
Altitude, weather, and terrain very likely could be causing the disparity in MPGs. OP should post where he towed, which route, etc. to have an accurate comparison.
I didn't get my Rappy to tow, other than maybe my flat bed with my RZR or maybe the Scout from time to time. That's why I have the Super Duty.
Didn't get the Raptor to haul all over. Except haul butt in the desert.
http://www.fordraptorforum.com/attachment.php?attachmentid=96146&stc=1&d=1516239742
This set up runs about 4.500lbs. Winter blend fuel, cold temps and cruising 70-80 mph I see 8.5-9.5. Parts of the Maine turnpike speed limit is 75
I installed the Hellwig swaybar. Made a big difference in towing, as a matter of fact big difference when empty.
To the OP:
To the OP:
Towing mode doesn't improve MPG's, neither does dropping a gear manually.
